bunch of snow and no play!! :(
wuts up homies .... im here in missouri and finally got sum snow for the first time with me owning my jk figured id terrorize the streets..lol .... but had a problem slidin it .... even with the esp turned off, when the rear end slides sideways somethin activates the front brakes .... i was wonderin if anyone has bypassed the braking system to where i can whip the back end around and do sum donuts .... so if anyone knows how id appreciate it ...thnx
try this it will disable it completey then it should be fun
1. turn jeep on
2. set to 4hi
3. set parking brake
4. make sure steering wheel is centered
5. turn wheel to the right, 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, you may hear a chime at 5 seconds(and ESP OFF may show up on the speedo), but keep holding for 7 seconds!!!!
6. Turn wheel back to center then left 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, again, hold for 7 seconds!!!
7. turn back to center, and hold ESP for 7 seconds.
8. Turn Jeep off
1. turn jeep on
2. set to 4hi
8. Turn Jeep off
1. turn jeep on
2. set to 4hi
8. Turn Jeep off
1. turn jeep on
2. set to 4hi
8. Turn Jeep off
Seriously ? Is this documented in the owner's manual ?
