Bumper light bar wiring
Hi
I'm looking for some advice on how to run the wires from my lights that will be mounted on a front bumper light bar. Do I run the wires down the sides? Where do the wires go into the engine compartment? Also where is the easiest place to run the wires from the engine compartment to the dash?
take off your front grill, get some zip ties and depending on where your switch is going to be, run the wires through the areas behind ur headlights and up the sides of ur engine compartment. should be plenty of areas to run or hide them with some zip ties
