Brake light not working I NEED YOUR HELP!!
I was working on installing a new license plate light. And I decided I was going to tap into the running light in the passenger side tail light. I cut the wires but then decided I didn’t want to do it. So I hooked the wires back up and now the running light is not working. Is there anything I can try? Please help me this is really stressing me out.
Are you certain you have a good connection? Did you solder it together or just use a cheap crimp fitting? If you disconnect the wires again, and you just touch the bare wires together, do the running lights come on?
