Bought KC Lights
I just installed mine today on windshield brackets. I mounted my relay and relay ground to a grounding screw next to the fuse box, wires to lights run under the cowl, relay power under fuse box to power in fuse box, and relay switch wire to 12v+ fog light wire. I don't use my fog lights on the street and my high beams are very weak. I figure the fogs will give me more up close to supplement the low beams and the LR KG lights will be my high beams (on crack).
As stated, I ran mine under the wiper cowl. Some of the wire will be visible, but its nothing a quick wrap of electrical tape won't help fix. I have, maybe, 4" of wire exposed. The rest of the wire is under the cowl and under the hood. Only about 3" of the yellow (relay power) is visible under the hood. Good luck!
