Better Siruis antenna?
Anyone upgrade their sirius satellite antenna? I know this has been discussed about how bad reception is through the trees. It is the receiver or the antenna that needs upgrading? My wife's XM works GREAT in the garage. If I get too close to the garage with the Jeep, the signal goes out.
In my very un-scientific experiment, I found that my Sirius reception is way better with the Freedom Top lids off (the front ones).
Places where the signal cuts out on I-64 in Hampton Roads are not a problem when I drive with the tops off.
I'm fully sure that this is a coincidence and not some "mod" or "discovery".
However, I put it to this august body - is there any chance there is a correlation?
Try moving it to the drivers side. Simple thinking really would of had jeep put it there. Just think, which side of the jeep is less likley to be covered with trees? the side against the center line or up against the tree line? believe it or not the 4 feet made a difference with mine.
I added a Sirius head unit to my JK so I bought an aftermarket antenna from amazon ($40 vs over $100 for a Mopar antenna). The brand is Terk, and I have it installed on the driver's side, on the sport bar (roll cage) just behind where the plastic header bar is located.
Still have some dropout of the Sirius signal when going under an overpass, but it's not that bad.
The sad part is my XM Roady had a better antanna than the one I bought. Never a lost signal with my Roady.
got antenna from circuit city and same crappy reception.....original did not work at all because of the padding and carpet I installed on top...lost total signal sirius sux!
while still....
i'd better put on my waders cuz it's gettin' a little deep in this thread.
don't know what you are refering to as far as under the seat...nobody said their's was under the seat?....mine was on top of rol bar and after i carpeted the top (actually 3/8 foil backed padding and then carpet) there was no signal....go figure for yourself....added ant. to hood and the signal came back but did not improve reception ...I have had xm and this sirius and as far as reception and quality of sound xm was hands down the winner...this was before the xm-sirius merger.
This is this first time I've had Siruis. My signal does flicker out sometimes in trees or underpasss but I'm totally surprised that it works in the underground parking garage at work. It's two stories underground with a high rise building on top. Why does a few branches mess it up but 25ft of concrete and dirt doesn't?
Thanks for the ideas. I am starting to believe that it is just the head unit in the dash that sux.
FYI, XM and Sirius have NOT merged yet.
http://www.signonsandiego.com/uniont...4satradio.html
Cliff notes:
They just upped the ante to the anti-trust committe with thier "a la carte" offer. To bad you will need a new radio to take advanrage of it!
Cliff notes:
Cliff notes:
Cliff notes:
