best wire size
This is what you should read- https://www.bluesea.com/resources/1437
As mentioned it depends greatly on the length of the run. For example at 15 feet 16awg will be adequate. The longer the distance from (the source - ground) the larger the wire you will need.
Also, I'm unsure of how you're going to wire them or your knowledge, but, make sure you wire the lights in parallel.
