Best Ppace to run wires
Best place to run wires
I've just purchased a set of KC 124s... I've not done lights before. what's the best way to get the wires through the firewall and into the dash on a 2011?
On the top of the firewall, drivers side. There is a rubber grommet. If you have a hard top, this is where the line for the rear washer fluid runs. I put all my wires thru there.
There is a foam-filled hole on each side of the dash. Just remove the side panels and push a wire coat hanger through, attach the wires, and pull them back into the cabin. There is a thread on here outlining the procedure with pics, but I'm on my phone and its a pain in the ass to search with the app.
