Auxiliary Back-Up Lighting
Old 12-21-2011, 11:17 AM
  #21
JK-Ford's Avatar
Originally Posted by SlowJK
You can just use one relay.
Ya, Like this. \/ \/ \/
I make my living working with control systems. I know that there are a bunch of other ways to do this. I only promote these 2.
Old 12-21-2011, 11:53 AM
  #22
MikekiM's Avatar
So... what are the details on the diode?? What size.. assuming they come in sizes.
Old 12-21-2011, 12:35 PM
  #23
Orangeav's Avatar
Originally Posted by omarf4
Best spot for me was above the third brake light.... I can swing away as needed while camping...... pics with full sun light out since july and they've held up nice.... just your standard $39 pilot lights from auto z!Attachment 252683Attachment 252684
Interesting...I kinda like this idea. Any light spill back into the Jeep when backing up?
Old 12-21-2011, 03:23 PM
  #24
SlowJK's Avatar
I wasn't saying you were wrong or anything of that nature, sorry if you took it that way.
I was going to say use relay tap in to the reverse light with a diode near the 86 pin. and also come off that pin as well (between the diode and pin it self ) to a toggle switch then to 12volt source.
Old 12-21-2011, 03:58 PM
  #25
7ESTES's Avatar
Part # for the PIAA back up lamps is 1540. Has everything u need to install, don't have to buy extra diodes or blinked fluid. Just saying there is a easy way to do this. Might be a little more $$$ but worth it to me.
Old 12-21-2011, 09:29 PM
  #26
Charlie Mike's Avatar
Where did you tap into the reverse light circuit? Wire color and location?
Old 12-22-2011, 03:18 AM
  #27
JK-Ford's Avatar
Yes there are many sizes. I believe that anything above 1 amp will be acceptable. Some of thes things are really small. So going larger is fine.
I took no personal offense to what you were say. But ( profesionaly speeking ) I am offended when someone recommends intentionally back-feeding a circuit. And relying on the diode to prevent the current from getting back to the electronics. As you can see in my drawings, I use the diode as a secondary line of defense. No a primary line of defense.
I tapped this circuit @ the driver side tail light because it was easier to find. And you will be passing the new circuits through this area anyway ( I followed the OEM circuits to the bumper ). You could pick up this circuit at the drivers footwell also. Sorry I do not remember the color.
Old 12-22-2011, 09:58 AM
  #28
texwillys's Avatar
I tapped into the reverse light circuit behind each tail light. Black = ground. White w/gray or green marker was energized in reverse.
Other Jeeps may be different.....check with your test meter to be certain
Old 12-22-2011, 10:19 AM
  #29
sringer's Avatar
Sweet.. I've been looking for a set to supplement the stock reverse lights... I already changed to LED's but that did very little.
One change I would like to make is to be able to switch them on both automatically with the stock reverse lights as well as manually for times I need to work behind the truck..
I have my lod bumper lights done that way. They come on with reverse and my rugged ridge a pillar switch pod has a switch for em. All of my reverse lights come on tho...from taillights and aux lights on the switch
Old 12-22-2011, 09:57 PM
  #30
Pop the 4 screws holding your taillight and pull assembly out (above license plate). Tap into the white wire ( check it in reverse with ebrake and wheel chocks on) that becomes active when you put gear in reverse.
Sweet! Thanks!
Quick Reply: Auxiliary Back-Up Lighting
