aux power for lights
I have been searching the forum i have a set of piaa lights that i am mounting on my bumper right now. The switched power wire can i just put a tap and 20 amp fuse in the M8 spot and that will be my switched power. I dont have heated seats so if i give that circuit power will it cause any problems. I know i saw on here what to do before but cant find it thanks everyone.
I tapped into my running lights, that way they can come on if I have my running lights on. Same thing I think as the keyed power line, but could be left on with power switch off.
Thats fine as long as you protect the circuit from short circuit ( fuse ) and reverse spike ( diode ).
You are correct. But the accessory circuit is the recomended method. Just a little added security.
