Aux input with factory stereo
Old 04-08-2010 | 08:44 AM
GON WHLN's Avatar
Default Aux input with factory stereo
Has anyone else had the problem with the AUX input on their stereo making a crunching sound while still playing the music.... If I jiggle the wire it gets better/worse. Yes, I have tried multiple new wires with the same effect.
Is there some quick fix or clean?
Old 04-08-2010 | 09:42 AM
mjturner1105's Avatar
Default maybe your cord
i had the head phone jack on my ipod do this i swore that it was the jack come to find out it was the cord broke in the plug twisting and wiggling it made contact. try a different cord before narrowing it down to the plug. just my 2 cents
Old 04-08-2010 | 09:56 AM
GON WHLN's Avatar
I have, i've gotten 3 cords with the same effect
Old 04-08-2010 | 10:27 AM
Tweakecho's Avatar
Mine seems loose also i havent tried to muck with it as of yet, maybe i'll get to it this weekend :P
Old 04-08-2010 | 10:44 AM
GON WHLN's Avatar
I've tried everything except crack open the headunit.... let me know if you have any success
Old 04-08-2010 | 07:08 PM
mdnky's Avatar
Where did you buy the cords? I've noticed the quality of the cords (mainly the connectors) vary widely. You may want to try one from someone like Monster Cable. A very loose rule is if it cost less than $10, it might be the issue. Assuming this is with an iPod: If you have an Apple Store nearby, try buying one there. Apple is pretty good about insisting the products in the store work perfectly with their devices. If its an iPhone, make sure you have the right connector. The 1st generation (silver backed models) had a longer than standard plug. There are adapters for this issue available (or cords with one longer plug.)
Old 04-08-2010 | 07:45 PM
ClownPoop's Avatar
Sounds like a bad cable to me... and no need to get over priced cables, a simple stereo 8th inch to 8th inch cable from radio shack should work fine...
Old 04-09-2010 | 04:09 AM
GON WHLN's Avatar
I've used the radio shack cables (2) and (1) $30 one from Best buy. All for the Itouch.
Old 04-09-2010 | 02:53 PM
LeroyJMC's Avatar
Do you have a lot of dirt, dust, and grit in the Aux port on the head unit? See if you can try giving it a swabbing with a small q-tip. The smaller the better.
Old 04-09-2010 | 02:57 PM
felix_434's Avatar
i have an iphone 3GS, and i swabbed out the hole in the phone and it helped. I also bought a new cord but it seems like certain songs with a specific frequency i hear the crackling sound. I also noticed it when playing a burned cd. I would suggest trying to clean swab your headunit, and itouch.
