Audio Experts - Will this setup replace base stereo w/o CANBUS issues?
Old 03-11-2015 | 03:44 AM
immortalmetal's Avatar
I bumped the thread for you. Between this, your headunit manual and the pac module manual, you should be good to go!
Its called "need help with aftermarket headunit wiring harness"
Old 03-11-2015 | 04:38 AM
notnalc68's Avatar
I wired a single DIN Sony into the '09 I had, with the same PAC unit, I think.
Old 03-11-2015 | 06:01 AM
14Sport's Avatar
Great! Thanks, immortal. Just what I need.
Old 03-11-2015 | 06:07 AM
No problem! I know what its like. That thread recall helped me out. The speakers were easy enough, match the colors. But then all the left over wires, I was like "whaaaaah? "
that thread really helped me out. Good luck!
Old 03-12-2015 | 10:44 AM
antpink's Avatar
Originally Posted by 14Sport
Thanks for responding.
Do you have the factory amp? It says you lose fade ability with the factory amp. Do you know if fade still works with an aftermarket amp? If so, I can replace 2 parts with this one.
Okay, according to PAC it combines those two items I have above so I will get this instead. Thanks, antpink. I'm going to update the first post with this change.
No factory amp - base stereo originally. Use ew HU pre-out to the aftermarket amp and you'll have whatever functionality the HU has.
Old 03-12-2015 | 10:52 AM
nosnhoj1's Avatar
This may be a little late but have you double checked the front wall of the inside of your console to make sure there isn't a usb port there?
Old 03-12-2015 | 11:04 AM
14Sport's Avatar
Yeah. My wife's has one but mine doesn't.
Old 03-12-2015 | 11:07 AM
14Sport's Avatar
Awesome. I think the amp is going to be the easiest part. Power, ground, remote turn on, a couple of RCAs and the speaker wires. It's all the other crap that I'm worried about. I think I will just tape all the connections to test it and then remove and solder the harnesses.
Old 03-13-2015 | 11:33 AM
14Sport's Avatar
So I made up the harness (still a couple of wires to solder) and did a test run before install. Everything works. I was having trouble with the rear speakers. I faded back and you could barely hear them. I tried switching the RCA jacks and the rears worked but not the front. Turned out the HU was set for rear sub instead of speakers. When did that become the default?! I bypassed initial setup since I would have to do it all over again tomorrow.
So tomorrow I will mount everything.
Thanks for the help guys. I likey.
Old 03-13-2015 | 01:02 PM
14Sport's Avatar
And I won't remember later for future questions so here's a picture.
Name:	RP4-CH11 Wiring (Medium).jpg
