Assistance on my DIY Distrubution/Fuse block
Hi everyone,
My engine bay looks a bit messy at the moment with the addition of extra stuff ... it is only going to get worse. I've done all my own electrical work but that is usually following write ups and common sense so some of the details elude me when making something from scratch.
Here is my idea, I am not sure if I can run that many things out of one little box, or even fit that much in one box.
On the diagram, #1. would my fused distribution blocks. Probably this. 6 Circuit ATC ATO Raised Fuse Block With HOT Wire Lead Fuse Terminal | eBay
#2 is just a splitter. #3 I am not really sure about. I would have to account for everything running at once wouldn't I? at at least the common ones as I don't want to keep popping fuses. The green squares are the relays.
Off hand this is what I have to wire up.
Switched Power via the Relays
Always Hot Connections
I am hoping I can squeeze the whole thing into this box. ML-58F*1508 Polycarbonate Electronic Enclosure with Clear Cover - Designed to NEMA Rating
Am I out to lunch with this? or is this something that will work.
Thanks!
- Bumper Lights
- Windshield Lights
- Rock Lights
- Reverse Lights
- Headlights
- Fog Lights
- Heated Seats
- CB Radio
Thanks!
It may work to put 4 or 5 relays in the box. Depending on the amperage you may have a heat issue with a plastic box. Make sure you put an appropriate fuse between the distribution block and the relays. I would not run the other block in there it would be too much happening in there.
Have you considered something like: CirKit Boss®™ Auxiliary Fuse Block/7 Circuits/Weatherproof
Thanks! I didn't catch that at first but it is a bit ironic
