Anyone try the E3 Diamond Fire Spark Plugs ?
#61
My JK is stock from a drivetrain/body/tire & wheel perspective - I wonder if those of us that are running stock are experiencing improvements that those running mods are not......
#62
I stopped by Pepboys today. Didn't carry E3s, but wasn't necessarily dead set on them as a had to have...I picked up a set of Bosch Platinum +4s. If you look hard enough, you can find positive and negative comments on anything. What are your alls feeling about the ones I picked up? They are pre gapped and seem similar in that there are 4 prongs running up to the electrode.
#63
Update
Well I replaced my plugs at around 4900 miles, I had a rough idle that I really did not like with the stock plugs. I noticed an immediate difference in the idle with the new E3s. The idle was much smoother and I no longer get the rough idle that lasted about 2 to 3 seconds.
I now have ~2000 miles on them since the change, and am still happy with them. I have noticed only one session of rough idle, after being parked for 8 hours in 100+ degree day.
I did not notice any mileage improvement after the change.
My plugs looked like tkob1060 after only 4900 miles.
#64
I picked up a set from the local Advance Auto Parts...$6.99/each The only thing is, I checked them when I got home and 4 of them are the same length...but two of them are slightly longer on the threaded end (maybe 1/8" longer)....that can't be good. I called Advance and they ordered some more, so now I'm gonna have to go back and make sure ALL of them are the same length!
#65
#66
I just intalled the Bosch Platinum +4s this AM. They are similar to the E3s in that they have several prongs leding up to the electrode and do not require gaping. Not too bad of an install, but definately have a swivel and some extensions on hand (swivel head socket wrench was a plus). Use a good spark plug socket as you won't want the plugs falling out as you snake them out from those tight spaces. Just take your time and remember the orientation of the plugs on the passenger side to make reinstllation easier (they are all tilted back significantly) as you can't really see the holes. The lift on the jeep didn't help!
Always a good hint to blow some compressed air at the current plug before you change it to prevent crud from falling into engine.
I did remove the brackets on the passenter side for the heater hoses and pulled off the large rubber line going to the airbox.
Used antiseize (there was none on factory plugs.
For those not using a torque wrench, 13-15 ftlbs is barely past hand tight - be careful!
On the initial post install test run, it seems to have mor pep on acceleration. So hard to tell. Will keep an eye on milage on the dash.
#67
#68
OK, I got mine straightened out...went to O'Reilly Auto Parts and compared the E3's that I had to the Champion plugs that came from factory...the "longer" E3's were the ones I needed, so I made sure to have 6 matching plugs and the install went very easy. As stated, a swivel head plug socket, extensions, and a long handle ratchet really helped!!
#69
