Anyone seen this switch set up???
Found this surfing, said it was on the "Overland JK" that is/was at the SEMA show in the Chrysler/Mopar booth.
Anyone know anything about this? Best switch set up I have seen so far!
It would be a little more complicated to wire I think.... I like the lower daystar panel because you have both of the ignition hot and constant hot power wires right there and its simple
more than likely it is not that susceptible to interference. Also they would be better off being triggers for relays since wiring would need to be a minimum, making for very low current/magnetic field on the wires.
Thanks Cuda. I think this is an interesting idea and I pretty much know nothing about wiring.
Only thing i see is they are using a factory switch panel for a rubicon it looks like. I'm not sure how they altered the switches to work however. They are all momentary switches (for use on our JK's can-bus). Fairly useless to the average Jeep owner.
