Anyone got upgraded hdlights? HID??
#41
Don't mean to resurrect this thread but I was doing some research on HIDs installs and ran into it.
This place sells a Canbus Fix wire but the site doesn't list H13/9008 as a fitment size.
CANBUS Fix
I already emailed them asking if they have one. I'll post once they reply.
CANBUS Fix
#42
CANBUS Fix
CANBUS Fix
#43
The stock headlight lens are the real issue,, if your going to the trouble of going HID please go for a real set of lenses.. you can put in the cibie or hella h4 lens then get the HID to fit that.. you will have a much better beam spread than the POS stock lenses/headlights..
#44
CANBUS Fix
CANBUS Fix
39.99 + shipping is way to much they are making a killing off those!
#45
i just finish the installation of my 6000k bi-xenon Hella HID kit
the canbus fix is way easier to fix than ALL the way i can found here
a 5ohm resistor in parallel do the job , now the computer see a 55w bulb, not a 35w
i will post some pics soon
#46
where did you purchase the HIDs from and was it a plug and play kit just plug it in and do the fix?
#47
the kit is sell as plug n' play but you got to tweak the CANBUS module with a resistor to get the 55w/65w current
i simply put a 5 ohm x 50w resistor between the positive and the ground, and everything works perfectly. no spark , no buzzing
the most difficult part is to find the 5ohm resistor , that takes me about 5 minutes
