Anyone got comparison shots between the Truck Lite LED headlights and stock JKs?
The JW Speaker LEDs have a fan inside that blow warm air from the heatsink forward to warm the lens for that purpose. Pretty nifty.
The fans are rated at 100,000 hours and make a pleasant little whirring sound.
Are JW speakers about 4300K or 5000k?..also noticed they dont cover much of the immediate front area, a bit ahead of your bumper...
-Christopher
I had a MINI with factory HIDs and I hated the lights. But I really like the LED light and can see well by it.
Delta bulbs lowbeam:
Delta bulbs highbeam:
Then, same Rubicon, same Hella reflector, same aim height. We swapped in an old set of Phillips Xtreme Power +80 60/55 bulbs.
Phillips Xtreme lowbeam:
The maximum LUX value was incredible for this combo.
Hella's highbeams are a little too high and the lowbeam is a little too low for my taste. It's a good reflector if you live in Florida or other flat state and do lots of interstate travel on cruise control.
The Delta bulbs are just as bad as PIAA, Silverstar, or IPF; avoid those if you actually want to see where you're going.
Bogdan at Delta did tell me that their lights are available with clear bulbs too; and they have a DOT compliant reflector in the works. I know they have a passion for lighting; I just hope they drop the non-performing products.
The Speakers don't unless you get hit by a bad angle.
That's one of the drawbacks of a lifted vehicle when you talk about lighting. The angle of the light changes so much when we go up and down hills that our lights shine all over the place. Add the bounce effect of our springs and the dynamics of braking, etc, and you can see why we get flashed so often.
We've developed an unscientific test called the "walking toward the Jeep test" to subjectively measure glare harshness. The Deltas and IPFs were the worst; you couldn't walk back to the Jeep without squinting in pain. The Speakers and Cibies were the best and you could keep looking right at the Jeep.
The Cibies aren't made anymore, correct? What available lens today gives as nice as beam pattern as those? Are the cibie replicas that are available any good?
