Anybody change out front /side markers to Recon LED"S
Was just wondering if anyone had these and did you buy as a set or did you buy 2 sets . I was on their site and saw that only 2 come in the box 1 per side ..but when reading posts on the net people say they have the side markers also ...I guess ..I should just call them...thought I could get some info before ordering.
I had them for a while, on both the front and sides, unless they fixed them i would stay away, I had them replaced twice because the 22 gauge wires would brake off at the connector, they did look good but i was tired of getting them replaced
Do a search for these....several past posts
I would return (or cancel if you can) the recons, buy a $15 can of vht nightshade, tape off the front and side markers (without removing) and 3 LIGHT coats... cheap easy and you saved yourself a TON of aggravation from not dealing with recon or their cheaply made products...
