Another HID install question--HELP
Old 09-20-2008 | 03:22 PM
bubbabeer's Avatar
Default Another HID install question--HELP
ok so I installed the bi-xenon kit with relay (to get more juice to ballasts) I turned on the headlights and worked no problem, then started up motor then they turned off with the headlight switch on. I know I have drl's but with the headlight switch on it should power them up!! My question is why? I think I have to connect directly to the battery with a on/off switch which I will locate on the steering housing. Any suggestions?????
Old 09-21-2008 | 01:46 AM
simov_mincho's Avatar
The problem exists that , as launching the car, the generator grinds easy variable electricity out and alone the relays cannot be included.
See that link https://www.jk-forum.com/forums/show...hlight=buzzing, Whether they do not twinkle, try with capacitor with more capacite 200mF
Old 09-21-2008 | 02:28 PM
bubbabeer's Avatar
So can I just connect directly to the battery, with a separate on/off switch??
Old 09-21-2008 | 04:57 PM
bubbabeer's Avatar
The kit has the inline capacitor already!
Old 09-22-2008 | 03:03 PM
bubbabeer's Avatar
anyone? Thanks
Quick Reply: Another HID install question--HELP
