Another headlight question
Old 07-31-2010, 02:47 PM
2wheelz4me's Avatar
Default Another headlight question
I have read several strings about different types of headlights, (HID, XENON, Halogen, etc.) and realize like anything you can basically spend as little or as much as a guy/or gal wants to. What I am waning is a sub $100 improvement over these stock lamps. Some of the one's I have seen are more white and appear to be brighter but seems like you lose some of the width of the beam. SO in short, what is the best alternative for just a low cost improvement over stock??
Thanks!!!!
Old 07-31-2010, 05:21 PM
tazzdogsocal's Avatar
Default don't go cheep
Save up and get the good stuff , I run cibi'e , I here good things about IPF. I did find cibi'e knockoffs for 75$ at a swap meet there better then stock but don't compare to original, So save and buy quality . A good light refracts with the lens not the reflector, you have more control where the light go's and you don't need big bulbs 55/60 work just fine.
ID:	79477   Click image for larger version
Old 07-31-2010, 05:48 PM
gtin's Avatar
Default Re: Another headlight question
I went with the ipf upgrade and all I can say is that they are worth every penny. The difference between those and the stock are like night and day. Even though the lights are brighter with the better focused beams I hardly ever have people flashing their high beams at me now compared to the old stock splatter lights.
Sent from my Droid using Tapatalk
Old 07-31-2010, 06:31 PM
BFAbPT's Avatar
same here, i went with the ipf headlights from northridge4x4 ... its a cheaper upgrade and easy install
Old 07-31-2010, 07:24 PM
Vernnz's Avatar
IPF from Northridge 4X4. It is higher than your $100 limit but it was the best $164 I spent on the JK.
Old 07-31-2010, 07:44 PM
flounder's Avatar
Ipf from northridge, put em on couple days ago. There fantastic
Old 07-31-2010, 08:56 PM
holson's Avatar
yah, I just put a set of cibie 7" h4 housings + 55/60w narva +50 bulbs on my gf's 09 jk and it's night and day.
i wouldnt even bother with anything less than actually replacing the headlight housings.
I think the IPFs at $160 is a great deal.
I paid $270 for the cibie setup:
$82 for the Ford H13 -->> H4 adapters
$192 for the cibie 7" housings + Narva +50 55/60W H4 bulbs
grand total $272+ (incl. shipping)
Pocket the beer/liquor money for a bit
Old 07-31-2010, 09:30 PM
matt852's Avatar
don't mean to hijack but are those lights on the bumper lightbar legal to run with your headlights on road? What are they?
I went with H3's or H4 lamps I think at 4wd about 79.00 very good lamps
Old 07-31-2010, 09:58 PM
fadeout's Avatar
Ipf's from northridge they're 100x's better than stock. I hardly ever use my fogs anymore to see the road.
Old 08-08-2010, 08:41 PM
Sapper12b's Avatar
ok been reading this thread and i do agree that the headlights are dependent on how FAT your wallet is. So i decided for the time being to do a cheap upgrade by changing out the light bulbs. Well i quickly discovered that it requires some disassembling to comfortably change out the bulb.
Now Ive changed many light bulbs in my many years of existence but am i just a retard or something because i cannot get the bulb to come off the grey plastic housing bracket. I know there is a little red switch that holds the bulb to the bracket but why cant i pull out the bulb to replace it, is there a trick to it or a magic word i have to say ?
Quick Reply: Another headlight question
