Another garage opener mod
#21
That was my thought also when I looked at this. If I was to do this, I would just tap into the constant on 12Volt power adapter. Most garage door openers run off of a 9VDC battery. So alls you need to do is buy a 9Volt Zener diode and a resistor, wire those parts onto the +12volt B+ wire, connect those to the battery wire connections of the remote and you never have to worry about changing the battery.
Also by using the jeeps key on 12 volts as a power source you'd have to have the key on to open the door... Great idea!
#22
Originally Posted by wittys-jk
I would have to say that is a pretty damn good first post great contribution for sure!
Great work OP, nice and clean job. I like it
#23
#25
