Another garage opener mod
Old 07-08-2012, 05:41 AM
  #21
Blksilverado's Avatar
Originally Posted by Rednroll
That was my thought also when I looked at this. If I was to do this, I would just tap into the constant on 12Volt power adapter. Most garage door openers run off of a 9VDC battery. So alls you need to do is buy a 9Volt Zener diode and a resistor, wire those parts onto the +12volt B+ wire, connect those to the battery wire connections of the remote and you never have to worry about changing the battery.
Also by using the jeeps key on 12 volts as a power source you'd have to have the key on to open the door... Great idea!
Old 07-08-2012, 06:22 AM
  #22
Wartoy's Avatar
Originally Posted by wittys-jk
I would have to say that is a pretty damn good first post great contribution for sure!
^^^ this.
Great work OP, nice and clean job. I like it
Old 07-09-2012, 08:32 AM
  #23
HAMMHOCK1's Avatar
Originally Posted by FirewalkerSahara
I've never done any soldering, is it pretty easy? I'm assuming you solder the wire to whatever connection is for the button to open the door?
2 wire hook up not a big deal I'm sure you can find someone to help you solder the wires in place. You need to be careful not to overheat the circuit board
Old 07-09-2012, 08:36 AM
  #24
Chewmeista's Avatar
great mods everybody
Old 07-09-2012, 08:57 AM
  #25
eumel789's Avatar
Great safety feature!
Quick Reply: Another garage opener mod
