Another garage opener mod
I took the center console arm rest out, and removed the side panel. Attachment 335218Attachment 335221
I split the door opener and soldered wire on the contacts to run a remote momentary push button switch. velcroed the opener to the inside of the panel. Drilled hole for the switchand mounted. Attachment 335224Attachment 335225 This is my first post hope the pictures came through
That was my thought also when I looked at this. If I was to do this, I would just tap into the constant on 12Volt power adapter. Most garage door openers run off of a 9VDC battery. So alls you need to do is buy a 9Volt Zener diode and a resistor, wire those parts onto the +12volt B+ wire, connect those to the battery wire connections of the remote and you never have to worry about changing the battery.
