Annoyed with lights
Annoyed with lights
I installed hella vision plus and the kc h4 conversion pigtails. The bulb on the passenger side went out and I pulled the bulb, it was fine. Installed +30 bulbs on both sides about a month ago. The passenger side went night night again tonight. The bulb is fine, again. Not sure what's up. Driver side has been fine. Any ideas?
That's what my hids did, I would have thought that was only an hid problem.... Ur hellas are halogen right? Maybe a bad conversion harness? Just a thought. And did u try to switch ur driver and passenger lamps to see if the problem goes to the other side? If it does u know its that physical lamp that's bad
Sent from my obama monitoring device
