Amp draw of led offroad lighting?
Old 11-27-2014, 03:52 PM
ade
ade's Avatar
Originally Posted by spanky1989
Does anyone know where I can find what amperage an led offroad light/led bar/ spots and such draw? Working on my own version of a relay box and I'm looking into using the smaller relays that can handle 10/20 amps. I have a feeling that I'll be ok doing 2 lights per circuit but want to be sure before I get too far into it. Thanks for any info or advice.
Put a multimeter in the light circuit and read the current drawn.
Old 11-27-2014, 06:39 PM
spanky1989's Avatar
the meter can only handle really low amps. I think around the 5a range.
Old 11-27-2014, 06:52 PM
ade
ade's Avatar
Most meters have a 10amp connector socket. Usually label as such. 55W LED lights are usually in 4-5 amp range. You can also use a high current meter. Which is an induction coil that goes around one wire that will read upto 100-200 amps.
Old 11-27-2014, 07:02 PM
ade
ade's Avatar
You can also make an induction coil by rapping wire around the conducting wire and read the voltage from it. Quite straight forward maths will then give you your current drawn.
Old 11-28-2014, 04:44 AM
spanky1989's Avatar
Yea I have one of those meters that is supposed to work with my multimeter but it dosnt, tool salesmen gave me the wrong thing.
I'll look into making my own like you mentioned.
Old 11-28-2014, 04:46 AM
spanky1989's Avatar
Now that I think about it one of my books from diesel tech school probably has all my answers in it already.... Now if I could find the damn thing.
Quick Reply: Amp draw of led offroad lighting?
