all left corner lights not working
So I went to San Felipe, Mx this weekend to the baja 250 and some idiot rear ended my trailer and broke one of the lights. the light socket got crushed together. After that, when it got dark, I turned on my lights on noticed that my hole left side was not lite. The brake light and blinker work, but not the corner lights. Any help would be appreciate it!!
It could have just simply blown a fuse when the trailer light was crushed. My 06 Silverado has separate fuses for left side and right side trailer only lights
Those have fuse M17 in common. It also powers the license plate light. Are you sure you checked all of the fuses? It wouldn't hurt to double-check that one. Then, check the area around the damage for any wiring damage. If the fuse is blown, you may have a wire/connector that's touching up against bare metal, shorting things out. Otherwise, you may have a wire that is powered by that fuse that has become broken. A good visual inspection of the damaged area is the best place to start.
