Alarm Question: Does Anyone Make This or am I Dreaming?
Go with compustar. It can be installed to work With your factory key fobs and you can add drone to use it from your phone. Hands down the best option. I work for a stereo shop so I've used all types of alarms and compustar is by far the best!
X2 on the compustar!
And if you get the ALCA bypass from Idata link you can use a plug and play tipstart harness that Idata also makes so the only wire you will be actually running is the siren wire!
