Alarm
#22
My rear window on my soft top was slashed. I lost my luggage and my laptop. Sucks! I would like to buy a Viper with the two motion sensors on the inside. In addition, I want the outside invisible approach warning. Do you guys know what I am talking about.
I think with the alarm you guys a re looking at would have worked for my stuff. However, my window still got slashed at a cost odf $350 BUCKS!! I want to keep them away as well as protect the inside. Any suggestions?
Thanks
pikejd
Thanks
pikejd
#23
Only problem with that, is that if someone makes it into your car without setting off the alarm (ie: cutting a hole thru the canvas/soft top window) then they can just hot wire/force the ignition and get away with your jeep...
#24
Bummer on your rear window dude :whoaisme: Somebody need to make a sticker that says, "DO NOT CUT THE CANVAS OR PLASTIC WINDOWS, Just open the door, or unzip the window. Steal my stuff, but please don't damage my Jeep!"
Rear trunk--it's only accessible when the rear gate is open. the top is hinged (and has a prop rod) for easier access. Here is the MOPAR info: 82210313 add a trunk 211.60. I think it's a "gotta have" if you run with your top down.
How come the the rear window replacement was so expensive? Complete tinted window kits from Quadratec are only about $200.
