Airbag light
Airbag light
The airbag light in my '10 jku has been on for about a month now. I've plugged in a diagnostic engine code reader and no codes were found. I've looked at the connection under the driver seat but haven't been able to look at the passenger connection because it's pretty hard to get to. Does this sound like a clock spring issue or a poor connection issue elsewhere? Thoughts?
Sounds like a clock spring. Join the club. It's about 200 or 300 hundred to fix your self. Or you may get lucky with a dealer. Better off asking Santa and hope your a good little jeeper😉
Former Member
What year Jeep?
I got a note from Chrysler about a way extended replacement policy on clockspring for my 07.
If you bought used you should let them know you are the new owner so you now get the warranty/recall notices
I've had my 07 for 2 months now. The light comes on randomly and goes off randomly. No clue but I haven't really looked yet. Will follow for fixes.
sent from my work leash
If it's an 07 it should be covered. I went in for my leaking trans lines. They denied that but informed me of a clock spring recall,for my jeep. Doesn't hurt to ask.
Sent from my iPad using JK-Forum
