aftermarket stereo without an aftermarket harness?
firstly i have an 07 wrangler x with the factory infinity system... is it possible to remove the factory h/u with infinity sound system and install an aftermarket h/u without the wire harness adapter? i have installed many car systems but have never dealt with chryco's canbus system. i don't mind running all new wiring since i would install a different amp to power all the speakers in the jeep. i just don't know if removing the factory head unit and amp will cause an issue with the operation of the canbus system.
i bought this thing new in 06 and haven't changed the stereo because i am not familiar with the canbus system. but i can no longer stand the factory system anymore... i have the need for more POWER AND SOUND... can anyone help me out?
i did it with a 08 with out the infinity system... wost case you might loose your chimes... which might be a good thing.. but i had no problems at all.. i installed nav DVD .. couple of amps sub woofer.. new speakers with out a harness.. the system was just separate from the jeep for the most part.. you shouldn't have any issues.
