Aftermarket Soundbar Speakers
Old 10-09-2008 | 08:40 PM
hyatt147's Avatar
Default Aftermarket Soundbar Speakers
I want to start shopping for speakers to replace the ones uptop in the sound bar. Are there any special things i have to look for besides the diameter. For example depth. I have no idea how deep that area is and the other thing is the mounting. It has to be a clean one you know. Are there any brands that will make the mounting perfect or are all speakers the same with that. Im not that familiar with speakers....yet
Man Law: When you start shopping, you become an expert
Old 10-09-2008 | 09:21 PM
Henri's Avatar
The speaker size is 6.5. I don't think the deepness matters because you have planty of room in the soundbar...you can even put some dynamat in there if you want (i did on mine). I have boston aucustics and they fit no problem. Btw the size for upfront is 6.5 also.
Old 10-09-2008 | 09:44 PM
hyatt147's Avatar
How did the speaker swap go? does it make a big difference?
Old 10-10-2008 | 07:36 AM
def9112's Avatar
i swapped all 4 spks out and they sound better but still need a lot of work because i cant *hit with the top off
I am going with a JL Audio amp and a bigger subwoofer
