Aftermarket Sound System Questions
Kinda honing in on the Rockford Fosgate P3D2 10, the Sundown Audio SA-10, or the TC Sounds 10.
I've been out of the car audio game so long the only brands I've used that I have any faith in are RF and JL.
JL just seems so pricey compared I anything in it's class and the RF don't seem to have the power handling to manage 1000w. Although I could wire it to 4ohm and just let the amp coast along.
I use two 15" TC drivers (older titanium version of the Axis) in my home theater driven by 4000 watts (2000 watts each). I use a commercial amp on a 220v circuit. They handle a lot of power with little distortion. They are Excellent woofer and able to play very low in a big box. Mine are ported and tuned to 8hz. Yes you read that right, 8hz - it moves the hair on your legs - haha. I bottomed one of them out damaging the titanium cone and they replaced it for no charge several years ago. Nowadays, there is a charge to replace a cone.
The benefit of the Fosgate woofer is that you can go into any store and listen.
You can tell I'm kind of a bass freak for an old man.
Thanks Mattk! I ended up pulling the trigger on the Sundown Audio SA-10 in dual voice coil 2 ohm config.
I think it was $189 on Amazon.com. Pretty affordable for something with the specs/reputation it has. Should be able to give it anything it could want at 1 ohm. Expecting I'll be able to reduce amp gain and still get loads of bass.
Putting it in a sealed enclosure with .77 cubic feet of interior volume... A bit more than the .5 SA lists so perhaps I'll get a bit lower but maintain the cleanness of a sealed box.
Still have to sort out the mids and highs. I'm leaning toward a Kenwood double DIN HU, and I'll have the mids/highs amplified as well, but I'm not sure what they'll be yet.
Question for folks that have updated their HU...
Someone said their radio doesn't play unless the vehicle was running? Did they hook it up incorrectly or is that common?
One of my favorite things is with the doors off, you turn off the Jeep and the radio keeps playing for about 20 seconds. Does that still happen with aftermarket?
Where are y'all routing heavy gauge power wire (1/0) from the battery through the firewall?
Can always drill if need be but I wanted to have a plan.
. Open up the doors and pop of the end caps on the dash. There is a hole up front filled with expandable foam. You can push a hanger through and it will go through to the engine compartment. Easy.
Cool. Thanks y'all. Tackling wiring back to the amps tomorrow. Got the new HU installed tonight. Haven't had time to mess with it, but it's in there and seems to be fully operational.
