Aftermarket Remote Starter
I have a Basic JKU and am installing a remote starter using the T-Harness available from iDataLink. I am also using their module and an Autopage remote starter Unit.
I have the wiring correct and verified and have done the module flashing and programming per the instructions. I seem to be getting only one way communication, to the jeep. If i lock the alarm the horn honks (i have aftermarket door locks), but if i open the door the alarm does not go off. If i try to lock the jeep with a door open the alarm beeps back saying the door is open.
Also when i try to remote start the unit the remote says Engine stop and shows no other icons.
Trouble shooting:
If i ground the Hood pin wire it says engine stop and shows the hood open.
When i try to enter programming mode on the starter/ alarm unit it doesn't seem to be detecting the key on/off sequence.
Any thoughts?
Hopefully there are some current 12 volt guys out there that are wiling to help a former 12 volt guy.
Trouble shooting:
Any thoughts?
