aftermarket amp install
Hello,
Was curious if I could tap into the white harness on the amp (infinity) for high level inputs for an external amp. This will be my second install like this but was hoping I could get by without disassembling the upper dash assembly. In the past I tapped into the speaker outs from the headunit. From my understanding this would be the same supply taping into the white harness on the factory amplifier. Was just hoping for reassurance. Appreciate any help.
You want to get your signal after the factory amp. There are digital controls between the head unit and the amp to control things like volume, eq, fade,and balance. If you tap in before the amp you will lose these controls.
You really won't need to remove much of the dash, The amp is located beneath the steering wheel there is a maybe 22" panel that just pops out. I would assume the harness will be connected to it so why do u need to pull apart the dash? There should be many posts on this site for installing aftermarket or just adding another amp ...try the search tool (you may have to read through some to find what you want )
hope this helped ...all I got!
I went through this, just go aftermarket head unit. The factory one sucks so bad and with the time and money spent trying to make it sound good, you will end up wishing you went aftermarket.
If you do want to keep the factory HU, I have an Arc Audio SRI I will make you a deal on.
SRI | Arc Audio
SRI | Arc Audio
Thanks for the replies. I have done an install in the past by using the wires from the head unit. This was on a base (non amplified) stereo. Im assuming you recommend taping in post amp because your implying all fade, volume etc. is controlled by the amp unlike the non amplified head units. If not, I would not think an amplified/eq'd supply would be the best option. It seems odd with the head unit having speaker outs that there would not be an out put controlled by the volume knob of the head unit. I was hoping to use these wires using the factor high level inputs on my amp, JL Audio JX1000. Funny thing is I put my hard top on yesterday and I am really not thinking a sub is as needed. The difference is crazy with hard top installed. My concerns with asking the original question is the fact I dont like taking the dash apart if its not needed. That upper panel seems fragile from past experience. I was hoping by using the harness before the amp I would only have to take the bottom panel off.
Thanks.
Thanks.
