AEV Bumper and Rigid D2 Fogs?
I did a search but can't find any information. Has anyone fitted Rigid Industries D2 LED's into the fog holes on an AEV bumper? I know there are brackets to fit the D2's into the factory bumper - will they fit the AEV?. I'm about to pull the trigger on the bumper and lights but need to know before I spend the $$$$
I will be ordering that kit from northridge and putting them in my aev bumper( i have the older gen full front with the big winch grilles and welded on light tabs). It should work since aev replicated the oem mounting system to reuse the oem fogs.
And u better believe that i will hardwire the led's to the high beam lights as well as the oem fog connector so that it will work when requested on low beam and always on high beam
I do know that JW Speaker are soon to release a direct bolt on fog light setup for our jeeps. Might want to check them out. Model number is 6145. Good luck with everything.
