Advice on items needed to install a new head unit/DVD player with nav.
I normally take my crs to a radio shop but I would like to try to do an install on my own. I have been quoted $590 for a DVD/Ipod head unit (no Nav) installed. If I install i think it will cost me more but think it will feel more rewarding. So if you have installed one yourself, which model and what harness did you use. And also where did you get the mounting bracket? I would like naviation, ipod and DVD.
Thanks
Thanks
It's all plug and play. I'll find you the link I used to install mine. What system do you have now.... Infinity or non infinity.... They require different wire harnesses depending on what set up....
Here's the link.... It's a tight fit! I installed a 7inch screen. The only scary part was using a sawzall because I could not find the dremel!!!!
https://www.jk-forum.com/forums/show...lpine-IVA-W205
Good luck
Good luck
