adjusting headlights
well sure as shit early this morning coming home from work in the dark and fog it was obvious I need some horizontal adustment as well. In just the dark they were fine but the fog showed the right beam was crossing over the the left. I met several cars on a two lane and never got flashed so that was good.
I wish it had an easy way to adjust so you could do it parked some where in the fog and get it adjusted without having to pull the grill and headlight.
ya it gives you a center line , the light center is same on the wall as on the jeep,
then fine tune vertical on the road. because even the garage slope's down out the door,
if i'm full of it please let me know. the factory lights were off the marks, got better after
after adjusting , then installed cibie's , had to do it all over.
ok last night was extremely dark and no fog and man do these light up the road on high beam. With out the fog I did not notice any beam crossing issues. Much better on low beam too but nothing like high beam. Never got flashed at all on low so my up down adjustment must be ok and still no flicker.
