adjusting headlights
i have my tucklites in nice and snug and notice that the passenger light is aimed to the left a little too much. when I'm about 15ft from my garage, the lights' x's are about 2' apart but when i back out, the passenger side x crosses over the the left, eventually overlapping the driver side x. the other night i noticed this the most in the dense fog my area was experiencing. i know how to adjust the lights up and down which i have done already, but is there a way to go side to side? i know i can shim the light but id rather not if there is a way to adjust. thanks guys!
I'm pretty sure there is a torx adjustment screw for horizontal as well as verticle. Not close to my jeep right now but I seem to remember seeing two beveled areas when looking at the headlight where you can fit a torx driver.
i thought so too but that other beveled area turns up blank. theres nothing there
I just did a quick google search and apparently we are out of luck as there is only one adjustment screw. Apparently in some markets JK/jku's have an electric motor that adjusts the headlights multi ways but we only get up and down. I just installed mine today and have not yet tried to adjust them but hopefully will tonight or tomorrow.
is there any way you can put pressure on the side of the light to get a little adjustment? I know mine felt like they could be manually moved a small bit. Maybe adjust them without the grill in place and use something to wedge in behind the light assembly to cant it a little.
I had same trubble with my 09 - found a adjusting nut INSIDE the light bucket, light has to be out to get at it .
don't know if the 12s are different , I made a mark where the light should be - removed light adjusted - held it in place by hand, and repeat till deadnuts on - good luck.
how i did mine
back in to garage or comp. level area ,
make sure lights are square to door - measure
mark corresponding measurements on door.
next take a Prozac cas this is FRUSTRATING
