Additional interior LED lights
Old 12-22-2013 | 05:04 AM
  #41
Arctic Blue's Avatar
Very nice. I'll be doing led foot well lighting soon. If that's not sufficient then I'll do these.
2012 Sahara Arctic Edition
2.5" Rock Krawler Max Travel
Spydertrax 1.5" spacers
BFG 32" Mud Terrain
GIVE UP OR DIE TRYING
Old 12-22-2013 | 02:59 PM
  #42
Chemlight's Avatar
Thanks again to the guys that helped me square this away.
Old 12-23-2013 | 02:48 AM
  #43
jfrohock3437's Avatar
How do you "tie into" the dome light? I know next to nothing about wiring. Pics would help. Thanks
Old 12-23-2013 | 03:58 AM
  #44
countrydude1992's Avatar
With LEDs, they draw next to no power when used in small amounts (strips, led pods, etch. Check the ricer aisle at the local auto store)
Luckily they draw so little power that you can wore then directly into the factory system and not really effect the CANBUS.
So basically, positive to positive (solid yellow on the dome light)
Negative to negative (brown on the dome light)
And boom, you have additional lighting that will come on whenever your dome light comes on
Old 12-23-2013 | 06:19 AM
  #45
Grand Umpah's Avatar
Or you can solder them to the aluminum leads on the back of the dome light housing
That's what I did; avoids having to splice wires
You can either use a volt meter or just touch the wires of the LED to different pairs until you find the right combo; very easy and no risk to the LED
You need a number 10 torx bit to get the screw holding the dome light out
Old 12-23-2013 | 07:49 AM
  #46
Chemlight's Avatar
These guys know more than I but I just spliced and heat shrunk my connections. Good to go
Old 12-23-2013 | 08:05 AM
  #47
I would just splice the wires in. Do the dome light wires run down the driver or passenger side?
Sent from my HP 7 using Tapatalk
Old 12-23-2013 | 11:23 AM
  #48
Originally Posted by Arctic Blue
I would just splice the wires in. Do the dome light wires run down the driver or passenger side? Sent from my HP 7 using Tapatalk
Yes. It turns into yellow with white tracer at the connector on the sound bar
Old 12-23-2013 | 11:33 AM
  #49
I guess here is what I'm getting at. I want to install foot well lighting wired into the dome light, so when I turn on the dome light the footwells light up as well. But I do not want to run wires from the footwell all the way up to the dome light on the sound bar.
Old 12-23-2013 | 01:39 PM
  #50
Riptide9's Avatar
Vet Army
Just connect to the wire loom that runs down the passenger foot well... same as the wire in the sound bar. I set up white strips in the side of the foot well near the ground bolts.
