Adding Stock amp question
First off let me say I am no good in the stereo dept... so I apologize in advance....
I got my X model JK with just the basic CD player.... no sub and no amp..... I then replaced the basic CD player with a MyGig that I got for a good deal. ...
Now there is a guy selling a stock amp and the harness...... (Yes I have read about the Nitro Amps)
If I buy this he states the harness will just plug into the MyGig from the amp. Guess my question is this.... fine..... but what do I plug the Amp into.... to get power to the amp and such..... Should i already have the set up for it even tho the Jeep didnt come with the amp?
Any help would be great..... i know there have been some on here that have switched them in and out.......
(I think. I need to convince someone I work with who has a JK without the infinity setup to let me take a look. I've been failing at that, and now the weather sucks.)
Sorry.
That said, if it's nice on Monday, he did say we could take a look and I can let you know then.
(He wants to go aftermarket, and we were wondering what wires WERE back there.)
'09 X 2-door with single disc, 6 speaker, non-Infinity, Sirius stereo. I was under the steering column two weekends ago.
I do not think the wiring harness for the amp is there because...
1. There were NO extra wiring harnesses under the steering wheel.
2. All speakers were driven straight from the H/U. All were indentifiable by small printing on each wire.
3. For now I have speaker wire run from an aftermarket amp to the dash and splicing into the factory rollbar speaker wires. Later I will put in the permanent speaker wire from the amp to the rollbar.
4. I used the Metra wiring harness and initialized it when first powered on. I have no H/U codes or speaker codes.
hscrugby: If you have Yahoo! Messenger or MSN or AIM, send me a PM. I can take my laptop to the garage and use a USB cam if you want to have a look.
