Adding power door locks
![Question](https://www.jk-forum.com/forums/images/icons/icon5.gif)
Ok so i bought my Wrangler X and got a great deal because it was on the lot, But alas it doesnt have power windows/locks. Its a jeep you say you dont need that stuff. Well, i can do without the windows but i HAVE to have my power locks. I took my door panels off only to find it near impossible to get a look at the latch to see if i can hang a universal actuator on it. Does anyone know if it has an additional lock lever like the rear door has or am i stuck ordering the $87 lock/latches from the stealership? Also, if i order those is it possible to just hard wire them to my keyless unit (audiovox 9275) or are the chrysler actuators multiplex (MUX) internally or is that in the BCM. I know that when you tap into exsisting chrysler locks you have to use resistors.
![rolling eyes](https://www.jk-forum.com/forums/images/smilies/rolleyes-1.gif)
Ok Im not going to get that technical on this but I am also looking for power door windows and maybe some door locks. Windows just make it easier instead of reaching to roll it up doing 65mph because the wind is blowing to much for the little one.
How much do you think it would cost for a shop to do this? Drilling holes ? I'd like it to look as much as factory as possible.
Any suggestions?
Any suggestions?
i added power lock from ebay, yes there is a second tab for the actuator rod on the front latches just like there is on the rear, they are set up a bit different, and unfortunately i didn't take pics or do a write up. all i can tell you is that it will take about 8 hrs, and will be frustrating at time, but is entirely possible and totally worth it. when i do my power window install, i'll try to take pics of that and the locks. good luck
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
![Mad](https://www.jk-forum.com/forums/images/smilies/mad.png)
![doh](https://www.jk-forum.com/forums/images/smilies/doh.gif)
found these on ebay for a 4 door....is this approximately what it looks like?
![](http://a763.g.akamai.net/7/763/1644/v001/app.infopia.com/img/image/fp/extra/1/VPID/3831284)
![](http://img253.imageshack.us/img253/7974/addinglocksfu8.jpg)
Id assume that since there are 3 connection points and the factory setup only uses 2 that i could attach to the third, which again assuming is the one with the red arrow. am i wrong? the 2 factory points are obviously the door handle and the door lock....or are all 3 attached?
are the lock cylinder and the interior lock cable attached at different points or....
(edit) ok i see that the piece the arrow is pointing to actually has 2 connection points and im hoping that is where the interior lock cable attaches.
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
(edit) ok i see that the piece the arrow is pointing to actually has 2 connection points and im hoping that is where the interior lock cable attaches.![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
Yes, it took some work to get it removed from the glass, and be able to remove the whole thing, but i did end up removing the entire interior panel for the project.
