Adding Nav to 2018 Sport
Bluestar1 (08-27-2019)
It is plug and play but you'll need an unlock code. The newer JK's (to my knowledge) come with a Sirius/ GPS antenna so you'll only need one antenna to handle both signals. I put a radio from a 15 in my 10 and couldn't get GPS to work. We put it in my friend's 15 (base radio with the upgraded sound system) and his GPS worked perfectly.
I would caution you though- you can usually get a good aftermarket radio that will work well for the same or cheaper and it will be a longer term product, unless you're dead set on factory products like I try to be.
Bluestar1 (08-28-2019)
Great info! Thank you for the reply. I like the idea of using a factory piece for this specific application.
