Adding factory sub
Adding factory sub
I need some help. I bought a factory sub off Craig's list for a good deal. I have a 2011 with the base sound system. I want to run the sub off an aftermarket amp using a Loc and the factory head unit. First question can I hook up the loc to the speaker wires that would have hooked up the sub if it had one. They are directly behind the sub. If not can I hook them up behind the factory head unit. Second question the sub has 4 wires going to it, I assume its a dual voice coil. What is the proper wiring for this?
http://www.crutchfield.com/S-3DIKUiz...rs_wiring.html
