Added Fus/Relay Panel-Lots of Pics
#21
cooperbussmann.com/pdf/36090f1a-b434-4910-98ec-1870f1f2519d.pdf
Call the number at the bottom of that pdf. Ask for Anthony Doctor. I can't remember if that is his location or not. You might be told that he is in another location and get the number to it.
That pdf might also be out of date. They made some subtle changes to their part numbers. All configurations are (were) available but the part number was different from what I expected.
#27
Well I haven't got my parts yet. UPS tracking says they should be here next tuesday. Here is a parts list if you or anyone is interested:
Qty
Ord Item Number
Item Desc. Pack Price Ext.
1.00 46345
MINI FUSE AND MICRO RELAY RTMR
PANEL BUSSMANN 15303-5-2-4 EA 24.5400 24.54
2.00 46085
MOUNTING BRACKET FOR ATO / ATC
& RTMR FUSE BLOCKS EA 4.1300 8.26
Relays
5.00 75730
SONG CHUAN ISO 280 MICRO RELAY
35A 12V SPST RESISTOR EA 2.9100 14.55
Cavity plugs
100.00 39010
PACKARD CAVITY PLUG-GREEN
# 12010300 EA 0.0669 6.69
Cable seals
100.00 39004
DELPHI CABLE SEAL-RED
#12015899 CHANGED TO #15324983 EA 0.0644 6.44
100.00 39000
DELPHI CABLE SEAL-GREEN
12015323 CHANGED TO 15324982 EA 0.0630 6.30
100.00 39002
DELPHI CABLE SEAL-BLUE
#12015193 CHANGED TO 15324981 EA 0.0708 7.08
100.00 39001
DELPHI CABLE SEAL- GRAY
#12010293 CHANGED TO 15324980 EA 0.0634 6.34
Terminals
50.00 30069
METRI-PACK 280 SERIES FEMALE
12110847 TERMINAL 18-16GA EA 0.1089 5.44
50.00 31068
12129409 TERMINAL 16-14GA EA 0.1127 5.63
50.00 31069
12110845 TERMINAL 14-12GA EA 0.1091 5.45
Qty
Ord Item Number
1.00 46345
2.00 46085
Relays
5.00 75730
Cavity plugs
100.00 39010
Cable seals
100.00 39004
100.00 39000
100.00 39002
100.00 39001
Terminals
50.00 30069
50.00 31068
50.00 31069
