Adapt Harbor Freight Badlands Wireless Winch Remote to Quadratec Q9500i Winch
The title says it all.
I think I am going to try and see if I can retrofit this ... Harbor Freight Badlands Wireless Winch Remote Control to operate my Quadratec Q9500i winch.
I can't find the wiring diagram for either, but a review on the wireless remote site says that it only has 4 wiress... 2 for 12v power, 1 for in, 1 for out. I know my quadratec winch has four connectors, so I am hoping I can make it work.
Has anyone tried anything like this or able to give me any pointers?
Question.... do you trust wireless in this application... trust wireless from Harbor Freight? Remember, winching can put your Jeep in much worse situations than what called for the line originally. Failure could result in big time problems.
You'll have to find schematics.... wire up to in, out, and power (if required). I believe the Warn requires power and know the Superwinch does not. I have no clue as to whom these chi-com winches are copying, but assume it's Warn? You might get lucky and find the connector mates right up.
Plenty of positive reviews on the Badlands remote. A remote circuit isn't rocket science. Just a relay switch.
Downside to the wireless remote is they have a slight delay. You just have to get used to it.
Have heard stories of other devices or interference activating the wireless controller. Again not first hand info so take it for what it's worth.
Well I got lucky.... my local harbor freight had a previously opened Wireless Remote for only $25... nice to save a few dollars since Im cutting it up anyway. Now to see if I can reverse engineer the wiring schematics for it.
My winch gets exercised constantly and many times safety is a concern. Positive, reliable control is important to me.
I just wired up a wireless controller to my engo. Was real easy +12v, ground, in, and out were the only wires to connect. The engo only has two solenoids (out,in). Once I figured out which one was which, I hooked the wireless control to them in parallel with the remote wires and was done. Now I can use either the wired or wireless controller.
Well that took about 30 minutes and it works perfectly. I just spliced the wired remote controller plug into the wireless remote control box, and now I have wireless control thats easily removeable so their is no danger of it activating from a random signal. When I want to use, I just plug in, and go.
For any who want to know how....
Quadratec remote plug wires - yellow/green = 12v, black = ground, blue = in, brown = out
Badlands Wireless Remote - yellow/green = 12v, black = ground, blue = out, brown = in
So yellow/green to yellow/green, black to black, blue to brown, brown to blue.
Just a very slight delay in the remote, not bad at all. Pulses well.
I ordered a spared Quadratec wired remote to carry as a backup should the wireless remote setup not work.
Yep. Exactly what I did.
