Accessory wires under dash
I'm looking for good options for tapping into accessory and interior lighting wires under dash.
1) accessory (key on power only) I already tapped into one from the factory stereo circuit that seems to working well but this a pitch to get to and not sure how much power I can safely get from it so I'd like a second option that is easier
2) I want to add some interior lights under the dash. Any good wires under there tied to the interior light circuit? I don't want to start hacking me up wires or probing around and risk damaging some wiring.
Northridge 4x4
Northridge 4x4
For switched power I got the plug and play harness from Quadratec that plugs into the dash power port factory wiring. I run my CB and radar detector from it. Its not for super hi drain devices. I think it had a 10 or 15 amp fuse. Easy to get to, the harness is long enough to pull out into the passenger footwell to hook up stuff then just tucks behind the center stack.
Sorry but I can't help with the under dash lights.
Ronjenx has a good thread about where you can tap for power out of the fusebox and I think it's 14sport has posts about which color wire and where under the dash you can find the dimmable interior light circuit.
For switched power I got the plug and play harness from Quadratec that plugs into the dash power port factory wiring. I run my CB and radar detector from it. Its not for super hi drain devices. I think it had a 10 or 15 amp fuse. Easy to get to, the harness is long enough to pull out into the passenger footwell to hook up stuff then just tucks behind the center stack. Sorry but I can't help with the under dash lights.
Can you post a link or specific product?
Northridge 4x4
