6 CD radio unit installed and not working ??
Old 08-25-2008 | 04:47 PM
racer83l's Avatar
im sure you can find the manual online.. google the sales code for the radio.
(If it was the mygig it would be RER or someting, I dont know what the 6-disc code is)
Although I have been pondering swapping my mygig for a 6 disc for some time.
Old 08-25-2008 | 05:27 PM
I did found the manual online but nothing about that shipping sequence combo......
Old 08-25-2008 | 06:05 PM
renegadelt1's Avatar
The shipping lock is in the service manual If that did not work Have you looked inside to see if anything looked out of place It may be worth a look, I just shipped one from FL.To TX. and it worked when it got there may be just lucky.
Old 08-25-2008 | 06:29 PM
bigbluejk's Avatar
I just recieved one from FL to TX and it worked perfect. Looked brand spankin new too. Some people are freekin awesome.
Old 08-26-2008 | 01:51 AM
can't find that shipping lock in the manual, I looked inside the changer and everything seems ok . When you shipped yours did you lock it with that code? or did it lock itself ?
thanks !!
JL
Old 08-26-2008 | 02:00 AM
71RTCHALLENGER's Avatar
Default Damn my memory
Sorry guys, totally forgot last night. I know it's there in the service manual, I'll write myself a little note so I won't forget
Old 08-27-2008 | 06:19 PM
Default Transportation Mode
NOTE: For REQ and RET radios, turn ignition to RUN and press SET + SCAN buttons Simultaneously to place the radio into transportation mode. The radio will display "Transportation" on the display within 5 seconds. If the radio is inoperative or not REQ/RET, skip this step.
Sorry I took so long. Hope this helps. Dave
Old 08-30-2008 | 06:09 AM
thanks for the info, I tried it but still no luck
Old 09-07-2008 | 07:40 AM
Default problem solved !!!!
I found the problem, here's a few pics in case this happen to someone else.
the ''thingy'' in pic#2 was jammed on that small tab, all I had to do was gently lift it pass the tab and voila!!
Old 09-07-2008 | 11:01 AM
Great glad you found it
Quick Reply: 6 CD radio unit installed and not working ??
