2014 Wrangler Radio Issues
Old 09-07-2021 | 09:48 AM
JoeyG1000's Avatar
Default 2014 Wrangler Radio Issues
Hello, I have a 2014 Jeep Wrangler and the radio is pissing me off. Satellite radio works, input/cd works, and radio turns on and looks fine, it just does not find a single station. I changed the antenna, checked fuse, and I'm at a loss.
Anyone able to help?
Old 09-08-2021 | 03:54 AM
CJ's JK's Avatar
Veteran: Navy
Did you replace the cable when replacing the antenna? If not, the satellite antenna and regular antenna have separate connections to the stereo, so maybe the regular antenna came loose behind the stereo. On my 2011 Sahara, there is also an adapter that lets the Jeep antenna wire fit replacement radios. (Every American and foreign car I have ever owned since the 80's had exact same connector, but not Jeep!) so that is another possible place it could be disconnected if you have an aftermarket radio.
