2013 Wrangler wont start
Old 06-01-2024, 08:46 AM
HappyFox's Avatar
Default 2013 Wrangler wont start
2013 Wrangler
battery has power and is brand new
Lights work, radio works
When turn key all postions work except when I try to turn in power dies. I replaced the ignition switch and jeep turned on but then i turned it off and it would not start again. Remived switch and replaced, it started but then once turned off, it would not restart. 3rd attempt and no luck turning on at all. Suggestions on what to do next.
Old 06-01-2024, 03:37 PM
Jay2013jk's Avatar
Welcome to JK Forum. From your post description, it will crank and start then after turn off it no longer ... Cranks?? or just does not start?
Old 06-01-2024, 03:55 PM
HappyFox's Avatar
After turn off it will not crank.
And thanks for the welcome.
Old 07-01-2024, 03:44 PM
hicksbilt's Avatar
Default HappyFox " Did you get your Wrangler to start?"
Originally Posted by HappyFox
2013 Wrangler
My JK is having the same problem. What did you do to finally fix it?
Quick Reply: 2013 Wrangler wont start
