2013 Front Speaker Removal
Start with the passenger side one first and you'll understand how much give the dash will bend ...pinch the sides of your glovebox and remove it ...from there you can access the speaker more easily manipulating it out after you remove the screws. It is a little unnerving to pull and bend the dash to get out the speakers but it can be done and after you get the hang of it the drivers side is a little harder but you'll know what to expect. Hope this helped ...there was a post of someone who included pics...use the search button .
Quickly did a search ...there are many !!
Here is one
https://www.jk-forum.com/forums/jk-w...rite-up-32611/
Here is one
There are two 7mm screws on the outer sides of each box that are accessible after removing the side panels of the dash. There is also one 10mm at the bottom of each enclosure. Remove those and then unclip the speaker plugs. Takes about 5 minutes on the passenger side and about 10 minutes on the drivers side. There are three other 7mm screws that make the drivers side take longer. They attach the lower dash panel to the dash support frame. Remove these and pull the dash away to slow the speaker enclosure to rotate out of the dash.
