2011 Jeep Wrangler HID Fog light kit
I'm trying to find out what HID kit I need for my fog lights. I have H13 8K 55w in my headlights. I hear H16 is what I need to get. Which one though 35w or 55w? I really like what I have in my headlights and was going to do the same with the fog lights. Will that cause me any issues? I would appreciate the help.
I have a set of yellow hid h16 35k sitting on my desk waiting to go on , if you search my threads I did a wright up on how to mod the stock housing to use the h16 or stock bulb , not sure yet if they are direct plug n play ballast , mine are can bus compatible but if the system has an issue withe higher wattage i have wiring harness to direct to the bat, if you can hang on a couple of day I'll let you know.
I'm trying to find out what HID kit I need for my fog lights. I have H13 8K 55w in my headlights. I hear H16 is what I need to get. Which one though 35w or 55w? I really like what I have in my headlights and was going to do the same with the fog lights. Will that cause me any issues? I would appreciate the help. Attachment 280759
Ok last night I installed my 35 watt 3 k yellow in my 2010 with only one issues the oem bulb plugs will not work with the ballast , I broke the original bulbs and sodered the connection end of the bulb to the ballast plug adaptor that came in the kit , I mounted the ballast to the inside of the bumper with some self tapping screws and used a couple of zip ties to keep the wiring kleen and tight,
Fogs are amazing know , sorry no picks but maybe later I will take a night shot.
Later on I will be updating the housing with hella projector s
